I need to fit a couple of new plastic rainwater gullies. I only need about a 1ft length of pipe from each new gully, down to get me past the 1st socket on the existing salt glazed pipes which I am connecting onto. I already have some offcut lengths of black above ground 110mm dia. soil pipe over, from when I Installed this previously. Would I be OK to use a short length of this below ground to avoid having to buy a 3m length of the brown coloured pipe.
Would the black soil pipe be compatible with the offset bend push-fit fitting which I need to fit between the gully and the pipe (to get the change in direction)
