D
dextrous
ColJack is an electrician, and not a very good one at thatbout time the plumbers had a ruck, this has got 5 pages in it at least![]()
However, my problem is that if I do all that, the tap flexi pipes won't reach the water supply pipes. I need some sort of 'extension'. Or a really long flexi pipe. But I can't seem to find one longer than 300mm anywhere. Any ideas?
the old flexis will NOT thread onto the new tap ends..the old flexi's won't screw onto the tap connectors as they are 3/4 threaded and the old ones are compression fit to copper..
obviouslywe're offering diffferent ideas here..
correctwhat you are suggesting is that she replaces the copper stub on the end of the old flexis with a longer one, and olive / nut it straight into the tap connection.
The trouble with saying 3/4 is that this will make her buy bath tap flexi connectors for a kitchen tap, which is the wrong size, curiously, as my photo of that double check valve shows.I was originally suggesting that she extend the copper on the wall and change the flexi's to one that is designed to fit onto taps ( I was assuming that 3/4 connector on a tap would be a 3/4 tap connector and not a male thread part of a compression fitting that has not been supplied with the olives or nuts to go on the end of them..)
Similar problem as above, plus the chamfer may cut through the rubber washer within the flexi, quite apart from the flexis apparently not being long enough, which is why I assume (my later Idea was to still use the flexi with the 3/4 tap connector on it ( still on the same assumption as above ) and just use the compression ( or pushfit ) join to connect to the stub of copper that's already on the end of the existing flexi.
Never said they would - they will take the copper extention bit with the olives and nuts.and the following statement is STILL correct..
the old flexis will NOT thread onto the new tap ends.the old flexi's won't screw onto the tap connectors as they are 3/4 threaded and the old ones are compression fit to copper..
The 15mm copper pipes with the nuts and olives on them become the female for those male threads.even if you take the copper stub out, it's still a compression fitting and threaded male to take the nut.. male to male do not screw..one needs to be female or a coupler used..
so you wouldn't recomend a steel sink then?
or is it monoblock taps that you don't like?
I will be doing the kitchen sink soon so need to think about it..
black worktop so silver sink would look better than the black or dark grey composite sinks and the ceramic ones I've seen are mostly light colours...
all the sinks seem to be reversible too and I don't like that.. the blank off for the tap hole you don't use looks rough...
Must admit, looking at a metal horseshoe washer, doesn't look like much room to play with to me. I'll take your word for itIf you put some large washers to "pad out" where the bolt tightens against the monoblock you can get them alooot tighter and no wobble on thin sink tops![]()
Kind of hard to explain so dont know if you got it, alot easier than using ridgid copper connectors though![]()
