Hot water from vent pipe
2 Apr 2009
Lancashire
I have a problem with the vent pipe that goes into the expansion tank. Hot water is filling the tank up then overflowing. I have tried to turn the pump to lowest setting but still no joy! any ideas please.
not uncommon, despite the barrage of idiots telling you it will never happen. If occassionaly, its ok, if regular , it`s a problem.
is it constant flow ?
is it when either heating or hw on ?
can be a faulty boiler stat
restriction in the pipework around vent/cold feed.
Is Cold Fewed & Vent Close Coupled in the airing cupboard,? if so the problem will be a partial blockage between the two pipes, causing the circulating water to expel over the vent and back down the cold feed, you should cut out the pipework around the feed & vent and replace, ignoring this problem will cause excessive corrosion in the system due to oxygenated water
It can if the cylinder coil is broken.
As any heatingengineer knows. :roll:
The expansion/cold feed pipe would fill tank if coil is leaking, wouldn`t expel from vent as any first year plumbing student knows, keep diggin` that hole. :roll:
breakdown monkey, stick with multimeter. leave labour/installs to real Heating Engineers. :wink:
When a system is heavily soiled, quite likely when it so bad that the cylinder has rotted away, the 15 mm feed is far from guaranteed to be free of obstructions.
Busted Mate. You know/ I know...... :oops: leave now whilst you have an ounce of credibility :wink:
