I recently replaced my HW cylinder and discovered that the supply to the immersion heater which has been there for 20 years has a e-n short.
This is a dedicated feed and the board end was not earthed but has an MCB.
Running a new cable is not practical so immersion is dissed.
I would like to use this for a pump feed however.
Would it be safe to use a seperate earth feed.?
Would it be acceptable ?
A 4mm single core earth is available which goes back to the board.
Any special labelling requirments ?
Edit, to be clear this has already been done but having now discovered it can i use it ?
I already know the answer to this but.
The only way i know of the fault is that i went looking for it after noticing something else.
Tests at the outlet revealed nothing untoward.
Earth loop, phase etc.
The socket mentioned was installed by myself replacing the origional cord outlet.
I would not normally open up a CU - notifiable work.
Any comments from those who replace immersion heaters ?
