But 110.9 is the Part Load efficiency (36/30°C), not the Sedbuk rating, which is about 90%. This gives a saving £1.5 per month. Big deal - wouldn't even pay for the annual service.Lets assume what they print is correct Atag Q 110.9 % efficientWhat would be your projected saving on my £45.00 a month standing order, assuming my Servowarm is 87%.
50p a month perhaps, or less.
you still haven't explained how the atag would probably use more gas as you said earlier doitall.
A certain science website, will have you believe that the average cost effective life of a modern condensing boiler is 3 years. Admittedly that was 4 ish years ago and they may have improved a tad by now.
Wasn't meant to! Just thought it would cause a lull in the discusssion while everyone digested the contents.But it doesn't answer the question Dave.
Not sure what you mean by this.Is efficiency a recognisable number.
Is 95% the same number for every boiler.Should be, provided the same method is used for calculating the efficiency - see SAP 2005 Though Sedbuk say:
Boiler efficiency tests are subject to a degree of measurement uncertainty. Consequently small differences in the efficiency values calculated from them are not significant and should not be relied on when comparing boilers. Statistical analysis suggests that if two boilers have SEDBUK values 3 percentage points apart then there is 95% confidence that the boiler with the higher value is more efficient.
But that's system efficiency, not boiler efficiency which is determined using a standardised set up.Isn't efficiency dependent on the system it's connected too.
For example a 85% boiler on a really efficient system, could in fact be more efficient than a 95% on and old draughty barn.
