I hope to finish fitting an outside bib tap soon, and would like a little advice as plumbing is not something I have any experience with at all...
All the pipework inside and out was already done as I am essentially replacing an old tap which was never much good (an ancient thing that didn't fit well onto the garden hose). The outside pipe burst near the old tap last winter (forgot to drain it...), so I have carefully cut off the bad end with a proper tube cutter, and deburred the new exposed end with steel wool.
The one thing that worries me most is fitting the tap plate to the pipe. The plate is a standard elbow connection which screws into the wall: 15mm compression end to pipe and 1/2 inch screw+PTFE end to tap.
I know I must not overtighten the nut, and that I need to use a wrench to hold the plate still (although it will be screwed to the wall) while tightening the nut. Here are my questions:
1) Is there a danger that the pipe itself will try to turn as I tighten the nut? Could this put strain on the connections inside the house?
2) Once the nut is hand tight, how much extra should I expect to have to turn it with the spanner? Different websites say different things - anything from 1/2 turn to 1&1/4 turns. Do I start with 1/2 turn, test it, then gradually tighten until it doesn't leak, but stopping and abandoning after 1&1/4 turns so as not to overtighten?
3) If it doesn't work, is it simply a matter of removing the plate, replacing the olive, and trying again? Or will the end of the pipe be too squashed after the first attempt...? (If the latter, how do I proceed without cutting off the squashed part of the pipe? This would mean drilling new holes in the wall to move the plate along
Any tips much appreciated,
Dave
Dave
