I am about to start on a renovation and extension of my little flat in West London. I was hoping for some advice as to who I need involved, and how much it is likely to cost.
First, here is something very close to my floorplan (this is a house down the road)
http://www.idoxwam1.lbhf.gov.uk/WAM...ntType=application/pdf&pageCount=1&appid=1001
Only difference is my bathroom is between the reception and bedroom (so there is just a massive corridor where the bathroom is in this picture)
Second, this is basically what I want to do.
I think it is quite nice of these people to do this planning for me! So, bearing in mind that these plans all exist, what would I expect to have to pay an architect (or a technician) to just convert them to my flat.
Plus, as I will have to remove a load bearing wall (this is a basement flat in a 5 story building) what type of specialist would be best to prepare the building control application?
Also, from the architect and/or surveyor plans, should I just be able to hand that to a builder and he can work from that? Including the load bearing wall removal?
And finally - if you can work out what I am doing from the plans - can anyone give me a guesstimate on the cost of the work? I have been quoted over the phone £45k for the extension, excluding installation! Which I think was a bit of a miscommunication on the nature of the work required (I hope!) but I wondered if someone could give me an idea, so I can at least compare it to other quotes.
Some other salient facts:
Flat is in conservation area, but the planning office has said that rear extensions shouldn't be problematic.
The other extension broke planning rules, but as it was retrospective, and no complaints they were allowed to keep it higher than a boundary wall is supposed to be (2M with 45 degree pitched roof). I know that I will have comply, so will have a slightly lower roof.
So, not sure if anyone can help, but i have used this forum before for plumbing problems, and it has been a great way to help with my confidence with builders/plumbers etc!
Kath
Kath
