If I have two electric showers ....
if you have a combi, why don't you supply one of the showers from that?
It's a possibility, the only downside being a long heat-up time compared with the Mira, as the boiler is two floors below the bathroom. This might not find favour with OH.
As OP says, since the plumbing is already there with a mains-pressure cold water feed, I considered instant electric shower first.
If the HW comes from the boiler at mains pressure, does the CW feed have to be mains pressure likewise?
yes
and you say you have already got it
the main difference is that this method will work, whereas installing a new CU and additional circuit for the additional electric shower will cost a lot and probably still overload your household supply
A gas combi shower will also supply more hot water than the pitiful flow from an electric shower, at lower cost per litre.
Main fuse (outside the cons unit) is 60A, the master MCB within the cons unit is 63A, as is the main switch within the cons unit.
That would mean:
Upgrade from DNO
New 17th edition consumer unit with suitable tails
Bringing the wiring and bonding up to spec
Then you can think about the new shower. Even 2 small showers will count for some 70 amps leaving 30 for the rest of the house. Only consider it if all your cooking is on gas.
The regs referred to in the link a couple of posts back appear to apply to England and Wales only - and I'm in Scotland.
Does anyone know if exactly the same legislation was enacted thru the Scottish Parliament?
you mean the Part-P?
there are "The Building (Scotland) Regulations 2004", of which Schedule 5, section 4, subsection 4.5 Electrical safety reads..
Electrical safety
4.5 Every building must be designed and constructed in such a way that the electrical installation does not-
(a) threaten the health and safety of the people in, and around, the building; and
(b) become a source of fire.
Limitation
This standard does not apply to an electrical installation-
(a) serving a building or any part of a building to which the Mines and Quarries Act 1954 or the Factories Act 1961 applies; or
(b) forming part of the works of an undertaker to which regulations for the supply and distribution of electricity made under the Electricity Act 1989 apply
which is more or less what the actual part P of the building regs say..
Schedule 3 provides details of what doesn't require a warrant ( scotish equivalent to notification ).
you're not keen on using teh hot water from your combi boiler then?
It will give a better shower.
Why is it that many flats can survive off one 60amp main fuse feeding two 10.5 kw showers, in two en-suites, without problems? :lol: :lol: :lol:
Has any one out there actually encountered things like tar leaking out of the service fuse in any Flats type installation with two showers??? :lol: :lol: :lol:
It is similar to fitting underrated tires on your car, they won't go pop until you put your foot to the floor for long enough.
How many flats have you worked in that have 90 kW worth of showers on a 63A fuse?
