That would mean:Main fuse (outside the cons unit) is 60A, the master MCB within the cons unit is 63A, as is the main switch within the cons unit.
It's not, but some work has to be notified to Building Control in advance, with a description of how you intend to comply with the Building Regulations, and their standard application fee paid.I'm not DIYing it if it's illegal to do so
http://www.diynot.com/forums/viewtopic.php?t=189034If we were to install one, could it share the same MCB, assuming the total combined ratings of the showers didn't exceed the MCBs capacity, or is there some regulation that requires them on separate circuits and breakers?
Electrical safety
4.5 Every building must be designed and constructed in such a way that the electrical installation does not-
(a) threaten the health and safety of the people in, and around, the building; and
(b) become a source of fire.
Limitation
This standard does not apply to an electrical installation-
(a) serving a building or any part of a building to which the Mines and Quarries Act 1954 or the Factories Act 1961 applies; or
(b) forming part of the works of an undertaker to which regulations for the supply and distribution of electricity made under the Electricity Act 1989 apply
depends on the boiler, and if the shower is thermostatic. flow from my boiler slows down dramatically as it warms up.It will give a better shower.
I'm curious - why would a correctly installed combi give a poorer output than an electric shower of merely half the power rating?depends on the boiler, and if the shower is thermostatic. flow from my boiler slows down dramatically as it warms up.It will give a better shower.
Because its an 18 year old Worcester 9.24e.I'm curious - why would a correctly installed combi give a poorer output than an electric shower of merely half the power rating?
So what's preventing it from delivering 24kW?Because its an 18 year old Worcester 9.24e.I'm curious - why would a correctly installed combi give a poorer output than an electric shower of merely half the power rating?
Why is it that many flats can survive off one 60amp main fuse feeding two 10.5 kw showers, in two en-suites, without problems?
