Baxi 105 Won't Reset
Just a little bit more info would help, like when does it nor start? When did the not starting start? Has anything been done?
Is the pressure between 1 and 2 on the gauge?
Have a look in the instructions for the overheat thermostat and then check that the button has not popped out on it.
Pressure is OK and there is only the power light on. It has just started happening.
Oh well, based on all the informative information you have given my diagnosis reads like this....
Its the thing that makes a switch thingy when the round spinning thingy is turning and sucking the stuff out.
Ps, It is a white one on the wall isnt it :oops:
Thanks for the reply, can anybody else help? Only one light on, the power light. Pressure seems OK. If I hold the rest nob over anticlockwise, nothing happens, should this relight the burner?
Overheat stat does not pop out on 105 its self reseting.
So you dont get a hot water demand light or Ch demand light
