Toilet on plinth
  • Thread starter Thread starter longdogs
  • Start date Start date
L
longdogs
Hi
I have been asked to install a new toilet for a customer in a downstairs cloakroom. The exsisting one is sitting on a plinth which is about three inches high. The waste goes straight out of the wall. He would like, if possible to remove the plinth - he says that when he first moved into the house the original toilet was not sitting on a plinth.
My question is: Does anyone know if I can buy a toilet which has an outlet of around 9'' (230mm) high- from floor to centre of outlet?
I don't fancy using an offset or flexi connector as I think 3'' would be too much of a step up and also would make the water level in the pan too high.
many thanks
Don't suppose he fancies the expense of having a wall hung pan - then you could set it to any height you wish :wink:
Good thinking but nowhere to hide cistern unfortunately. Room is tiny and behind toilet is a window.
Nothing springs to mind - pans I've used are normally about 190mm or so to centre of outlet.
