Stuck need some advice recently purchased a property with no central heating. Had a Worchester Bosch 24i junior greenstar Combi boiler installed a few months back opted not to have the radiators installed at the time because of the cost factor. I am a hands on practical guy and have decided to install the radiator system myself. I have done loads of reading up and asking around about the do and don’ts etc but still have some unknowns. I have calculated the total heat loss for the property @ 26827 BTU The boiler flow rate is 9.8l/min, Central heating output Min 7.2kw Max 24KW. I have opted to go for plastic pipe and push fit fittings. I will be installing 7 radiators in total and have decided to go for a feed and return system. I am now stuck at pipe size to use for the system should I be using 22mm pipe throughout and tee off to 15mm copper for radiator connections or should I be using 15mm pipe throughout (Except for 1m copper from boiler before going to plastic) ? Any advice and tips will be greatly appreciated. Thx
