- Joined
- 13 Aug 2009
- Messages
- 64
- Reaction score
- 0
- Country
Hi everyone, I would appreciate any comments you have on this re-wire suggestion.
The property is an ex-LA one with concrete floors and solid walls, the current electrics are run throughout the property in purpose built plastic skirting which also houses sockets, this skirting is being removed as it is in disrepair.
Our original plan was for new wiring to be run high up on the ceiling, which would then be covered with a new plasterboard ceiling. The wiring would then drop down the walls via chases. We now realise the current ceiling and walls are in good shape and are reluctant to do this.
As an alternative, we are considering raising the floor instead, with a layer of 15mm high density insulation board (to help with acoustic and heat insulation), on top of this would be 20mm thick wood board (the sort used say under tiling).
My re-wire suggestion is to simply run wiring in the 15mm insulation board layer, via dedicated groove cut-outs. The 20mm thick wood board layer will then cover it all.
Please advise on any obvious problems here? Any one have experience with similar situation?
I have an electrician for my electric work but would really appreciate the forum's input too, cheers.
