Hi... I've got a problem with my Glow worm Fuelsaver Complheat 80. It's completely stopped heating water and the radiators.
The boiler comes on as usual and you can hear the pump running, but it doesn't even try to fire the ignition.
I took the cover off and it talks about 4 LED's that should be lit up. These are: LED 1 - PCB Power, LED 2 - Thermostat, LED 3 - Air pressure, LED 4 - Pilot.
I'm only getting LED's 1 & 2 lit up, and under troubleshooting it's saying that if LED 3 isn't lit the diagnosis is "Air flow proving fault - that is fan or air pressure switch"
Can anyone tell me if these parts are still readily available and if it's a cheap thing to fix? I'm worried I'm going to get told it's new boiler time, and that's an expense I'd rather not pay out for at the moment.
All help/advice greatly appreciated - many thanks...
