paint on coving and ceiling
17 Oct 2009
Devon
Hope you can help,
I am at the moment painting a ceiling freshly plastered.
I have applied a misty, but i have now put on 7 coats of paint, ( silk).
Is there anything i can do to reduce this for the other ceilings i have to do.
also
Whats the best way to hide the join in coving, decorators cork or polyfilla and sand it back. ( or is there another genious way you pro's know about)
many thanks in advance.
Use a good coat of cheap contract matt as a primer coat. Use decorators filler for small gaps. Silk isn't a very popular choice to be honest, why are you using it?
I would use contract matt but definately not cheap paint cos the base paint can't be weak, and the cheap paints are not so good.
7 coats? strewth! Must be cheapo paint..( wont even mention what I think of silk!)
I just finished a 'new' plastered ceiling Friday morning, it took 3 coats , 1 mist coat ( Crown contract matt) followed by 2 coats Crown vinyl matt -proper trade from Brewers ..
7 coats? strewth!
Got to say that’s rather excessive, how much are you thinning the paint down? You only need 2/3 25-30% thinned mist coats on green plaster. Thinning emulsion a little always helps get a decent finish (despite what is says on the tin!) but 7 coats :shock: Paint will never cover cracks/joints no matter how thick it is; for the coving joints use a good, fine pre mix tub filler & just sand it smooth.
