you connected your pump between the cylinder and vent
not a spur off the horizontal pipe from the cylinder.
Hello seco services thanks for your reply, and I'm trying to visualise a spur which in electrical work means breaking into an existing circuit to tap off energy.
If that's the case should I remake the the direct pipe connection between cylinder output and the hot water feed/vent T piece, and the make a T to the pump output.
As I'm writing it doesn't sound right, so I've probably got your meaning wrong.
Please let me know as I've spent a lot of money and time on this project and would love to finish the job, and when you are nearly 76 and on a limited pension it's not always easy to afford having it done for you.
Regards vectraguy.
