I realise this is a common problem, but mine is slightly different to what I have read and I have tried most of what has been suggested.
I have a radiator like this one:
Except with more panels. But same design.
It has only been fitted last year, but has never really got hot at all. It had a TRV fitted, and I read that this type of Radiator should have just a normal tap valve, so this week I fitted one of those, but still it will not get hot. This at least rules out a dodgy TRV! So then I shut down all the other radiators, opened the valves fully on both sides of the rad, set the boiler to full wack, and its still cold.
The thing is, the pipes in and out of the radiator is really hot, as it too hot to keep your hand on. And other normal radiators in the house get too hot to touch when on full.
When I bleed it, water does come out under pressure, but its stone cold. And a bit dirty.
I have my boiler set to 1 bar, but then tried it on 1.5 bars, still no joy.
The bottom pipe that runs along the radiator (that the panels are connected to) does get warm, and the middle two panels get a bit warm till about 1/4 of the way up, but when I say warm, its not hot.
I would have thought if it was blocked, one of the pipes wouldnt get hot?
Also there are isolation valves on the pipes, but the pipes are red hot after that point. They are open fully.
The pipes run along above the floor, when I did the house up, we chopped the pipes at the point them come out of the floor, and covered them till I was ready to do that room, then ran chrome covered pipes to where the rad is (due to being above floor, looks better).
Willing to try anything !
Any thoughts? If it is a blockage
