Shower keeps going hot and cold
21 Nov 2009
I have a triton shower and it keeps going hot and cold.
It is about 5 years old just want to see if there is anything I should do before buying a new one.
Cheers,
Colin
Lots of advice in the tech forum at showerdoctor.co.uk
Hi Guys,
Its a triton T90si
It starts hot then goes cold, then hot, then cold.... if its cold and you turn it off and on it will start off cold again.
Thanks for your help,
Colin
its the pumped one.
try checking the inlet filter first.
then try running it without the showerhead on.
check the tco on the outlet pipe for any burnt wires etc.
Same problem but different model. I am guesiing though that the same advice applies yes?
Thanking you in advance :-)
i am having the same problem with a triton cara, then shower keeps going realy hot, then cold, . i have heard it could be the anti scald mechanism in the shower unit,
is there anyway of finding out if this is correct, if so, can the parts be replaced, or does it mean i have to buy a new shower.
regardsa
wayne
