Replacing Wax Seal on toilet question
20 Nov 2009
Hi all, I think I need to replace the wax seal on my toilet, a la these instructions here; http://www.hammerzone.com/archives/bath/fixt_repair/toilet/wax_ring/replace.htm
However my toilet has a pipe at the back, I assume that's where the wax ring will be and not underneath like on the website?
Picture;
Also, anyone know what this tap thing is? Its in a cupboard under the stairs, I obviously need to turn the water off before I fiddle with the bog - is this the water off tap? Thanks for any info
thats gas.
we haven't got wax seals on our toilets. thats probably an american site.
why do you think the wax seal needs changing ?
thats gas.
D'oh!
It's leaking around that tube thing at the back, I assumed after googling leaking toilet that that seemed to be the problem. What's the UK Solution?
personally looking at the pic i would get the longer connector the one that can be cut down.
as yours looks abit short. :wink:
The wax seal is an American setup. Their plumbing practises are different to typical UK installations.
The american setup came about because of the common use of vertical outlets from WCs dropping through the floor, with the connection out of sight to the plumber trying to assemble it. So they stuff the joint with a non-setting compound ('wax') and hope it seals itself....
UK practise uses a pan connector with a flexible rubber seal to fit the back of the pan, and flexible fins to seal inside the soil pipe. No 'wax' anywhere.
From the look of your piccie, there may be an alignment problem between the soil pipe and the pan, and the connector doesn't appear to be fully engaged with the soil pipe.
Trimming the end of the soil pipe, and using a longer connector may help on both counts.
Are you sure the leak is from the pan connector? leaks from the cistern to pan connection (doughnut washer) often end up dripping onto the pan connector.
A wad of tissue on top of the connector will soon tell if the leak is above it.
