My new oven has arrived without a flex and plug. My old oven plugged in to a socket in the adjacent cabinet controlled by a sfcu above worktop on the kitchen ring final. I chose this oven because it could be swapped like for like. However the manufactures instructions state it can be fitted with a 13A plug but it has to be 2.5mm butyl insulated flex. The only 2.5mm flex I can find is arctic flex at 10mm OD. Would this suffice ?
Why does it have to be such heavy flex when the singles used inside the oven look rather thinner ?
I have attached the manufactures instructions and a photo.
Thank you
Thank you
