Having just spend 12 days in my neighbours place in spain, I thought I would share a few of the lecky pictures I could not resist taking.
Firstly, the place is billed via a meter, but is on a 'green 5.5kw' tarrif.
Unfortunately, this means the supply is limited (via an MCB) to 25amp - with aircon in each room (as heating too), a water heater, oven etc, it is rather annoying! The MCB is sealed as can be seen in the pic.
Consumer unit with covers on.
Consumer unit labelling:
*Alumbrado (Lighting), all lighting.
*Otros Usos (Other Uses), a couple sockets.
*Electrodomesticos (Sockets).
*Cocina (Cooker), oven only, gas hob.
*Diferencial (Differencial), RCD covering all circuits.
*General (General), Main Isolator.
Sealed 25amp Merlin MCB limiting supply from lecky company.
This is a picture of the main consumer unit with the flange removed. Notice the electricity board sealed cover over the MCB limiting the load to 5.5kw.
Inside the consumer unit, because I knew you would ask.
Access panel and doorbell above consumer unit.
Doorbell - nothing much to see, but notice it is mains voltage! Never seen a FRIEDLAND 220v version before - it certainly sounds powerful when used. It is operated from a mains momentry action switch outside the door, and wired to the lighting circuit.
Wiring access - pull off cover, no tools required.
They use these decorated panels all over the place to show change of directions etc in conduit runs.
Pics are all here - I may add some more.
http://www.askthetrades.co.uk/cgi-b...wgallery;username=Lectrician;album=1260281091
