solid fuel stove problem
the cylinder and stove are on ground floor .i must go up ,across attic and back down for cylinder and the same pipe run back[up ,over and down to stove]. there is an oil boiler also ...thats no bother though ...my problem is the up and over pipe run for the stove.. could it blow up if i lost power to my circulation pump..
It allows cold mains to flush through the phe (on high temp rise) to drain, thus cooling the stove water.
