I just changed the diverter valve on my Worcester Bosch 35CDI II and when I tested it by putting the hot water on. The boiler came on wanting to heat the hot water then I didn't like the sound it was making so I shut the hot tap. When I went to boiler water was gushing out from underneath. I put everything back the way it should and put new O rings where possible.
I think the problem might be from where the fillinh loop assembly joins the plastic flow manifold because I can't get it to fit tight. refer to fig 40 on page 25 on the manual (link below).
http://www.google.co.uk/search?hl=en&q=worcester+bosch+35cdi+ii+manual&meta=&aq=f&oq=
Desperate for help. Can someone help? I'll waiting for a reply
