S
salmo
is it safe enough to just switch off mcb you want to change and removing this from busbar using insulated driver as there is no current flowing through mcb.Thanks for any info
bernardgreen";p="1458484 said:NO it is NOT safe.
Thanks bernardgreen.The reason i was asking for is that i was watching a friend replace an mcb in his board and all he did was switch off the mcb he wanted to change then he removed the live brown cable from top of mcb then unscrewed the mcb from busbar removed it then put new one in and tightened this one up then put brown cable back in tightened this up then switched mcb back on and was ok.Was this ok.
Is your friend a qualified sparky? Even then and using heavy duty rubber gloves it would be dodgy. That said you SHOULD switch off at the mains.
Very dodgy work practice and I'd imagine the HSE would take a very dim view should he have an accident or "monkey see monkey do" has an accident, for the sake of switching off for 5 mins.Is your friend a qualified sparky? Even then and using heavy duty rubber gloves it would be dodgy. That said you SHOULD switch off at the mains.
Thanks for reply Wingcoax spoke to him about this and although he is not qualified he says he does this all the time as working on premises that they have to leave supply on ie shops etc.He says that as long as the mcb is switched off then no load and touching of busbar with insulated driver you will not get shock , but he did say you have to be very carefull.
I've seen it done like this but it really shouldn't be. There is no excuse either. If the supply to the customer has to be isolated then so be it. This should have been made clear to the customer before the work started.spoke to him about this and although he is not qualified he says he does this all the time as working on premises that they have to leave supply on ie shops etc.He says that as long as the mcb is switched off then no load and touching of busbar with insulated driver you will not get shock , but he did say you have to be very carefull.
