Does anyone know what the hysteresis is on a Honeywell CM927
4 Jan 2010
Bedfordshire
I'm looking at installing a Honeywell CM927, or maybe the wired version. I can't seem to find out what the hysteresis is on this unit. Can anyone help?
Honeywell's spec says:
Temperature control accuracy: ±0.5 K (nominal) @ 20°C, 50% load 3KΔ/hour.
That spec may not exactly equate to the question.
Most modern controls allow the hysteresis to be set at +- 0.5 or +- 1.0
For most applications its not very critical.
Tony
You, I and the Nerd may all be talking about different things!
Many of the latest stats also look at rate of temp rise and not just actual temps.
Its a common falacy that a small differential in a stat gives better control.
In reality there are many other factors that come into play like convection currents from heat sources, draughts etc.
Tony
