compression
8 Sep 2006
hi, sounds like a silly question i know. Anyway when you buy a compression fitting do you get ollives with it? or buy them seperate? thankyou.
They come with them already in place. Always worth getting a spare bag of copper olives anyway.
Most do, I suggest the copper variety rather than the brass. Much easier to compress and get a good seal.
ptfe thats 6 weeker talk isn't it ?
A true professional will not use any jointing material on a compression fitting because its not necessary!
Many newcomers think its a good idea to add some as they have little confidence in their capabilities!
On an old fiting or where the pipe is damaged some PTFE on the inner side of the pipe/olive will usually make it seal.
If you ever see PTFE on the thread then you know the last person there was totally untrained!
Tony
thanks for everyones help. However when doing a compression joint, is it standard practice to use jointing compound? since alot of people seem againt PTFE. If PTFE isnt really for use on compression joints, joining pipes, what does it get used for? iv seen it on Radiator valves where they joint the rad.
Tony
Strange thing to say is that!!!
My current boss was one of the Top BG Engineers back in the day and is without a doubt the best engineer i have ever come across yet he insists that we use PTFE or Jet Blue on all olives just as he does.
Ps this guy drives both a Mitsubishi Warrior and a Land Rover Discovery Sport and has several vans on the road so he must have some idea!!
Cowboys and DIYers use PTFE on compression.
Plumbers use either nothing, or a smear of Boss White jointing.
Blah, blah, blah
Tony
If he's a top engineer, I can see why BG had to let him go! :wink:
He got to a point where he decided he could not be a salesman and actually just wanted to repair the faults and BG where having none of that, so he took retirement and set off on his own.
hmm i still say its good idea as give it lot longer before it will leak but can help it i use solder joints and end feed intgral are to expensive for what they are
