lighting.
16 Jan 2010
Durham
hi all i have two ceiling lights in my living room, both have their own swithes.
i want to have a double switch instead of two single switches, what is the easiest method please. :?
the new switch is to be in a different position as both single switches will be removed
Sounds like you'l have to re-route the switch drops from the current switches to the new location and fit an appropraitte 2 gang switch.
Is the room currently undergoing refurbishment?
How close together are the lights?
Are they on the same circuit? - does the one MCB at the fuseboard isolate both lights?
Do you have access to above the ceiling?
both lights are on the downstairs lighting circuit.
the living room is 22 ft long but i have removed a door from one end of the room so i no longer need that light switch. but i obviously still need the light. i want to operate both lights from one location.
just like staircase lighting.
Well than the simplest method would be to divert the existing switch lines to their new position, if you have to do a joint connection then make sure it's accessible and done accordingly.
Ideally, if you can gain access to both light positions and the new switch position from above, then replacing the cabling would be advised so as to remove unnecessary joints.
This is assuming that the supply isn't wired through the switch's
Do you know if there is an RCD protecting the circuit currently?
