I’m planning to get Bessie (the current boiler, 22 years old, a Gloworm fuel saver mark II with 15 kW of throbbing power!) replaced with a combi
I know you won’t want to miss this chance to tell me:
+ how terrible combi’s are and that it won’t work,
+ what I’ve forgotten,
+ that this or that brand is ace (or p a n t s)!
bet you can think of loads more…
Why scrap the old girl? Partly to free up some space and partly to improve the shower/ lower the gas bills/ hug more trees (and ‘cause I like risk!
So if you would gentlemen (and ladies?)
What won’t work?
What do I need to remind the installer about?
How do I avoid adding to the 28000 other posts with “combi” in them?
Maybe I should share…
Installer recommends a Worcester-Bosch 30 CDi. HW 12.3 l/min@DeltaT:35 C, or 11.5 l/min@DeltaT:40 C - CH loads of headroom.
The 37CDi as an alternative looks like overkill (and over££££).
Where?
For when it breaks:
Stopping it breaking:
Pressures:
Static mains pressure: 2.4 bar (measured using £11 screwfix gauge from monument).
Maintained pressure @ flows (using a bucket, set of scales and a watch):
Temperatures
Ambient mains water temp: 5 to 8 C (January!!!!)
The current bath hot tap (from vented cylinder) delivers 9 l/min.
The current electric shower delivers 4.7 l/min from the cold main @ outlet temp 43 C (will leave in and add a thermostatic mixer at some point so need fully modulating)...
What won’t work?
Where?
- Mid-terraced Victorian house. Moderately insulated. Leicester: hard water.
1 bathroom. 1 kitchen. 2 beds. 6 rads All with TRV’s. Half are new type 22’s, half are old pressed steel (bulges likely to appear!).
Mum, dad and 2 toddlers using the water/heating (so need variable temperature on HW to avoid bandaging scalded little hands).
Plan to site in bathroom airing cupboard: it physically fits, there’s leccy, external wall for flue and access to external drain. Bye bye cold water tank, CH header tank in loft, vented HW cylinder, wired thermostat, (oh.. and apparently reliable hot water and CH, any redundancy, etc).
22 mm gas pipe on outside wall to supply it. 3.5 m from gas meter.
Gas supply also serves gas fire and gas cooker.
For when it breaks:
- Gas fire in front room.
10.8 kW shower in bathroom.
Deep pockets.
- I’m already on first name terms with the installer.
Magnaclean will be fitted.
Descaler was mentioned, but if an electric jobby will get some of the supplied snake oil and use that to lube the pipes before replacing it with polyphosphate device.
Regular prayers to the heating gods and sacrificial offerings planned (see above reference to children
Pressures:
- Max flow: 22 l/min@ 0 bar (pressure drops to zero on outside tap when all other cold taps on – total volume calculated with a couple of buckets!!!)
18 l/[email protected] bar (my kitchen tap)
14 l/[email protected] bar (important this one as boiler only gives stated HW flow at 1.4 bar!)
Temperatures
