- Joined
- 10 Jan 2010
- Messages
- 15
- Reaction score
- 0
- Country
I live in a 5 year old house. About a month ago, the Mira Sport 7.5kw electric shower started tripping the RCD after about 5 minutes of use. I spoke with an electrician who said that it was almost certainly the shower unit itself and that this should be replaced.
i bought a new Mira Sport 9kw electric shower (the electrician confirmed that this would be okay on 6mm cable) and this was fitted by a plumber yesterday. Looking forward to being able to use the new shower today, it tripped the RCD again after about 5 minutes of use!
It clearly wasn't the shower unit at fault and now after spending a couple of hundred pounds on a new shower I probably didn't need, I am confused as to what could be causing the RCD to trip. There was no excessive power use today at the time the shower was being used, so I don't think an overload is the problem.
Has anyone any ideas what could be causing this? It is the RCD that trips, not the particular switch relating to the shower itself.
Any help much appreciated.
