Anyone explain how the hot taps get pressure? Cheers..
The CSW part is above the tap outlets. There is therefore a working head of pressureThere is no head created, otherwise it would be a `header` tank. They actually work when installed on same level as a bathroom. Seen loads don`t understand how, and why make them? Anyone with experience of these, now`s yer chance.....Ta... bungalows have `em...all the time...
Are you sure it's not a small thermal store with a header tank at the top? We have an Albion Mainsflow which has an internal coil to heat the hot water at mains pressure. I was confused at first because the shower head is higher than than the header tank bit.
HTH,
Bri.
Strange.....whole pressure thing is baffling, if these work ok, what`s the point of a header tank?what creates the pressure in the cylinder to push hot water out?
I think that the op's experience includes observing combination units providing hot water outputs at heights above the unit itself. This defies the law of gravity and, unless they are indeed mains pressurised units, a complete mystery.Not to drag up a sore subject, but it works because the outlets (i.e. taps) are lower than the water level in the header tank. Having a separate header tank and cylinder usually increases the vertical distance between the water level in the header tank and the outlet (as the header is usually located in the loft), hence increased pressure and flow rate at the outlet.
You could still have equal performance to a separate header/cylinder setup by putting a combination cylinder in the loft. I realise that certain members here wont agree based on a previous, shall we say, discussion - but I invite you to try it.
