K
Keston
We have never had the hot water flow rate quoted to us in litres per minute.
The boiler can only heat about 10 litres per minute to hot hand temp at a hot tap.
While running the tap at max see what the gas meter is doing. If a cu ft meter measure the secs to do a full rev of the test dial ( thats wthout any other gas appliances in use ).
If a metric meter measure the two indexs two min apart to ALL the places of decimals.
Tony
Stupid iPhone deleted everything I just wrote, here I got again...
The boiler can squeeze about 14 leters per min.
I personally wouldn't have put it to low gas as surely the heating would also be affected? Granted the hot water has a higher demand due to the boiler going flat out but even so I would expect howling noises or explosive ignition due to incorrect combustion settings.
I'm betting it's the diverter valve which a simple capacitor change would fix
