Hello
I have redecorated and am trying to replace an old Light switch.
It is older Blk and red wiring.
This is the way it works.
At the bottom of the stairs i have a double 2 way switch which operates both upstairs and down.
At the top i have a Single switch which only operates the upstairs light.
I have replaced the double switch downstairs, no problem.
But when i took off the old switch upstairs, i noted the way the wiring was and tried to fit a new switch.
The old permutation from the old switch didn't seem to make the new switch work so i tried switching around until i got the light working fine.
The only trouble i have is when the downstairs lightswitch turns on the upstairs light, the upstairs lightswitch won't turn it off.
I have one Red and Two Blacks wires in the upstairs switch and i have both a single 1 way and a single 2way switch i can use.
Which should i use and can you please tell me the way round the wiring should go.
Many thanks.
Many thanks.
