we're about to change our built in double oven and want to replace it with a single oven and a smaller combi oven/microwave. Our double oven is using a cooker point which has a 38amp cable coming directly from the fuse box. Is it ok for this 38amp cable and it's cooker point to feed both the new single and combi oven, or do I need to get it changed? I've heard that the combi/micro take a lot of power and want to be able to run both ovens at the same time. I always assumed that as a double was ok then so should a single and combi together - am I right ? Do I need cooker points or can the existing one be split into two. Need to know if I need to get the electrician in before I go out and buy them, or just get him to connect them up.
