Laying Cobbles
7 Feb 2008
Is this the correct way to fit 100 x 100 cobbles?
Will the edging cobbles come loose over time?
Many thanks.
dependent on teh mix, yes it is. You can do them on a wet or dry mix, although i prefer a wet mix if its not for vehicular traffic.
you really need to take out all vegetive material.fill with hardcore and then lay your cobbles to minimise any ground heave effect on them
Thanks chaps.
The cobbles are for light foot traffic.
What about if the ground is heavy clay, will they start moving in a few years? Am I best to get a more substantial edging stone, not as attractive as having cobbles abutting the lawn, but at least you know they will do the job?
its not the material you put on the top thats important but how you prepare the ground below.
The cobbles are only 50mm in depth which would only allow a small haunch. I meant should I get an adging stone which is deeper (say 100mm) hence allowing for a bigger haunch
Thanks.
sorry missed that on the picture. With chukka. you need a decent sub-base for them to be laid on, especially if it is clay. If its heavy clay i would be laying them on 150mm of mot for foot traffic.
The haunching is fine, if done properly they wont move sideways. Its the movement underneath on the rest of teh area you need to eliminate.
