Conductive adhesive?
23 Sep 2002
I've inherited a CH control unit, but the battery has been removed from inside. These batteries are supposed to be non-removable, so it's not just a case of slotting another one in. They're sort of spot-welded in, which I can't replicate. Obviously, without the battery all the settings are lost in a power cut.
I thought that an electrically conductive glue might be the best solution. Can anybody recommend one, or an alternative solution?
There are some conductive paints but as they are based on metallic silver they are expensive.
It should be possible to solder in a new battery or flying leads which can be attached to a battery.
The better suppliers can supply batteries with connections for soldering on to the PCB which is probably what yours had originally.
Tony
If it works - would you put the remains on eBay starting @ 99p. I need to do a car rear window myself - before next winter :wink:
FFS Instead of pyshing around spending money on things that will most likely not work throw your inheritance in the bin and buy a new controller from around £20. Surely you are not that skint :?:
Bought a CR2032 holder from Maplin for 59p, desoldered the existing leaf contacts and soldered the holder in. Works a treat and cheaper than £20 - although not sure where you got that price - looking at around £55 from Screwfix for like-for-like replacement.
Anyway, all done now. Thanks to all for advice.
I said from £20. You never said what type it was.
I can buy a car from around £6k but i can also buy one for over £100k!
Good you got it fixed :wink:
