I think you would get away with a good bit more than 10 to 12 mm thickness of bonding, especially onto a dried out slurried/bondit surface, simply because OF the rougher dried out surface. If it was onto a smoother surface, especially a ceiling, even though it had been PVA'd, i think you'd worry that the weight of the plaster might break the bond, and drop. When you think about it,, a coat of Bonding plaster, (lightweight) is at it's heaviest when it's just been put on. By the time it's dried out, there's no weight to it at all,, unlike a coat of render. I would never push my luck, and keep putting on a coat, thicker and thicker, but you get that gut feeling that all is well. I would obviously put more thickness onto a wall than a ceiling. I wouldn't normally use that sort of thickness anyway, but now and again, i'd come close to it if i needed too. Touch wood,,, i've never had any fall down/come away.
