Okay got a strange one here.
Due to an up and coming extension build i have had to make alterations to both my central heating system (removing 3 rads) and water pipes.
The heating went well apart from a bad back from lots of crawling below the ground floor
I thought the re-routing of the water pipes had gone well untill i noticed a change in the water delivery from the kitchen tap, the water appears to be coming from the tap with less pressure and the flow is not as smooth (Spluters) as it was.
Its going to be difficult to explain in words what was and what is but here goes.
PREVIOUSLY.
The mains water enters the house below the kitchen sink (Stop cock) from there it went to both the kitchen sink and als T,d off to the first floor where it picked up two bathrooms before coming back down to the ground floor and into the combi boiler.
NOW
The mains water enters the house below the kitchen sink (Stop cock) it picks up the kitchen sink and now T,s off too the combi boiler. Just below the boiler the cold also T,s off up to the first floor where it picks up the two first floor bathrooms.
Do you think what i have done has affected the water delivery at the kitchen taps and if so how can i fix it?? I,m thinking i may need a check valve somewhere in the circuit but am not sure??
Thanks in advance for any help.
Cheers
PREVIOUSLY.
NOW
Cheers
