Hi, my gloworm 30cxi has sprung a leak, well, 2 actually, the 1st one was from the thermostat (worn washer/o-ring) which i replaced, the 2nd seems to be a small pinhole on the plastic housing where by the the thermostat is located. Is this the LH Hydroblock? As you can see i've used some Unibond putty to try and "block" the leak as a temporary fix until I can replace the part but it hasnt really worked. Is this the LH Hydroblock?
If so, how much is it likely to cost? Im thinking of replacing it myself rather than getting a plumber out, as it doesnt seem to require any special tooling. Any advice welcome.
