Bosch Maxx WFL245S wash machine not draining or spinning
10 Apr 2010
London
:? Hi all,
My Bosch Maxx WFL245S washing machine isn't spinning or draining water??
Any advice pr tips please much appreciated
W
filter blocked, found at the front.
Hi Rocks thank you. I should have also asked for how to unblock it. I have absolutely no idea what to do. I can see the flap at the front and a round white disk that let's out water but not sure what else to do. Any more tips please?
Damsel in distress.
:roll:
yes that round disc unscrew it and water will come out see if any rubbish is in there, towels are needed.
I managed to watch an online youtube clip of how to drain out the water using the drainage valve but the filter itself doesn't seem to want to come out grrr :x
I've tried turning it fully but doesn't appear to want to come out. Will I have to uncrew anything?
HELLLP!!!
It's jammed with something twist it back and forth otherwise you need to take pump off.
OMGosh you totally Rock LOL Rocks1
It worked, fantastic!! I had nightmares I would have to get down and dirty and take the damned thing apart (which I really didn't want to do) or call someone out for an expensive repair.
Thank you this website is the tiSh!!!
Have agreat day and Rocks1 you should think about charging -you probably would be a millionaire  8)
I am a millionaire I do this part time other wise I get bored :lol:
Similar symptoms for me I'm afraid, but the filter on mine is clear but the problem continues.....
I have drained it and as stated above have cleaned out the filter. Now when I try to run the machine it simply makes a rather nasty moaning noise and won't play ball.
Any thought anybody,mother wise it will be a rather expensive Christmas😪
