Bosch Maxx Classic - Drum not spinning (brush replaced)- no click
8 Oct 2019
Israel
Here`s the issue I`m facing on my BOSCH MAXX CLASSIC Washing Machine :
1) Drum is not spinning
2) Found a post here about brush replacement - done that - still nothing.
I can hear the click and see a little motor movement for half a second and that`s it.
is it the motor or panel? Where to continue the investigation?
Belt is OK \ Water is draining out OK \ Motor is spinning by hand
Thanks a lot for any help
Used this post : https://www.diynot.com/diy/threads/bosch-maxx-drum-not-spinning.171737/#ixzz61lmgDpNo
Recheck the new brushes are not sticking in their holders & when pulled away from the commutator & released snap back under the spring pressure. Also clean & examine the com for signs of arcing or severe wear or other damage.
Well - opened again and re-checked. all was just fine.
Connected all together back and Boom ! the Main control panel exploded (at least sound like that)...
Took it downstairs to it grave....thanks for the help anyways
