Hi Guys,
just stumbled across this forum and I hope you can help.
I received a gas bill on Friday for 5 times my normal annual usage. I was on the phone to the supplier when i went out to the meter box. As I opened it I could smell gas. An engineer was dispached and there was a gas leak from the regulator, the valve to isolate the meter from the mains was faulty and did not operate, also when he was replacing the valve he mentioned that the flow control in the mains was still letting through 'an awful lot of gas'.
He replaced the regulator and the valve but said this wouldn't have affected the meter at all. I was looking a second opinion as i would have assumed for meters to operate correctly they would need standard inputs in order to measure the output. If something was off on the input then the measurements would also be off??
I'm currently testing to see if the meter spins without any gas being used but i suspect it is the faults that caused the bill
Thanks in advance
T
Thanks in advance
T
