hello hope someone can help, i have this boiler and the hot water is not working properly. turn the tap on and water takes a bit to warm up, when it does it isnt that hot then it gets cold. leaving the tap running still she gets hot again then cold (this just repeats). plumber has checked the diverta valve and all seems to be working fine between the water and central heating.
he thinks it could be the diaframme washer not opening fully but not broken hence the water getting a bit hot then cold. the boiler lights and turns off every 15 sec is this normal.
can someone please help its driving me mad
thanks in advance
thanks in advance
