I have a Wired Drayton Digistat 1 which is battery operated (2 cells).
The Programmer is a Honeywell 6400C with 3 On/Off and 7 day setting and the Boiler is a Potterton Suprima.
There is a Mid Position 3 port Valve.
When the CH is ON through Programmer), the Boiler runs irrespective of what the Thermostat setting is (even if the setting is lower than the room temp).
This is a new house we have moved in, so can't tell if it ever worked or stopped working recently.
I opened the Programmer and checked the connections.
Apart from the Ground, it has 5 wires connected :
Live, Neutral, HW ON, HW OFF, CH ON
Note that the CH OFF is not connected (and the manual says that is a valid connection for Y Plan). My local CH Engineer said that the CH OFF is never connected.
I suspect the Thermostat is wired wrongly.
I checked the suggested Elecrical Connections for a Drayton Digistat 1 and it says :
1 - Common, 2 - Satisfied and 3 - Demand.
However, on mine, 2 is not connected.
Only 1 (red) and 3 (yellow) are connected.
On the wall, there is a note listing the old Honeywell connections :
1 - red, 2 - blue, 3 - yellow, 4 - stat, earth
Do I need a wire going to 2 ? If so, which one ?
Any help / advice highly solicited.
