Hi all,
I'm going to fit 2 new Aqua Lisa pumped showers, so need to install a 13amp supply in the loft. Can this supply be a spur (bearing in mind both pumps could be running at the same time or does it need to loop back to the ring?
Alternatively, I have an existing dedicated 10mm T&E (I think) that is feeding a Triton electric shower that is going to be ripped out and never seen again. Could I use that feed (which is directly off its own breaker on the distribution board) to feed the shower pumps?
Many thanks, SJ
Many thanks, SJ
