I'm looking for some advice. I'm boarding my loft, we previously had the immersion heater removed and a combi-boiler fitted in a different location. I've found the old immersion heater wiring (single wire, not a ring) and I want to use it for a double socket in the loft. Am I right that I can just connect a double 13A socket:
http://www.screwfix.com/prods/15747...ts/White-Moulded/MK-Range/MK-13A-2G-DP-Sw-Skt
to a back box: http://www.screwfix.com/prods/19307...White-Moulded/MK-Range/MK-2G-40mm-Moulded-Box
And I don't need an fused switch before the socket? This wire (looks like 2.5mm) goes straight to the MCB and has a 32A CB there labelled "immer heater", I don't believe anything else is on this wiring.
Thanks!
Thanks!
