Worcester 35DCi RDF Combi is the description off the front of the boiler - it went in in the summer of 2001. It doesn't say 11 on the lid and so I think it is the first boiler. It is not a greenstar either. When a hot water tap is in full flow the water runs very hot, then runs cool, then very hot alternatly. Whilst it is doing this the HW demand light and the burner light remain on constantly. If the demand HW temparature control knob is adjusted to the lowest or the highest the temparature of the hot water does not change nor do the symptoms. If anything when the hot water is turned up full the flow turns cool more quickly - difficult to be sure this is the case though. From reading other posts there isn't 1 that exactly matches but similiar posts would suggest I need a new DHW Sensor? Switching off the boiler and removing the lid I can see the sensor attached to the pipe by a simple screw and the manual suggests I need some paste to attach it, the sensor only costs £10, is a boiler engineer required to fit it? Or is it more likley to be a different problem? The wife is driving me crazy - the plumbers I have spoken to want £50 to look at it which I don't mind if they fix it at the same time - so any help would be much appreciated. Thanks
