Terminating Pyro Cable
10 May 2010
Recently had a new garage door installed, and they had to move the consumer unit for the garage, which then broke.
Got a new consumer unit, and its connected up, but during the process I broke the feed to it.
The feed is 3 core copper clad pyro cable. Previously went into a small junction box. I need this reterminating, and I'm getting a bit stuck. I think its a bit beyond my skillset, however I've had a quote for £80 and a quote for £100. Seems a bit high to stick a new gland on and terminate for me?
Any ideas guys?
Funnily enough, I recently bought myself some pyro wire (3L1.5) and the associated glands, tools etc....
I've taken on a 'small' project at home and needed to terminate both ends of a 5 metre length.
Even doing the work sat at a workbench, I reckon it took me best part of 3 hours to strip and terminate both ends.... !! :oops: :oops:
I appreciate that with practice, I could speed these times up considerably, but it is a specialist skill and so unless you are a real enthusiast, I would say leave it to the professionals, and with that in mind £100 seems reasonable to me.
The glands seem to only come in 10's and the tools will cost you best part of £100.
A comendable post, I quite believe your time of 3 hours to do your first couple of terminations, they take me about 10 -15 minutes each once all the bits are in the same place but I have probably only averaged only 4 a year over the last 40 years. A fire alarm installer recently terminated a panel, in the same room where I was working, and in a day did about 40 cables, including forming them and fixing to about 3-4m tray. Big up to him brilliant job, I reckon it would have taken me 3 days.
It may sound a lot but IMO thats worth paying to have done properly, it will not be much cheaper to do yourself if you buy [or even hire] the tools and will take a whole day if you include the time taken to obtain the bits.
