Hi
I installed a self cutting garden tap last weekend - you know, the kit with the sleeve that goes around the mains pipe that you screw a tap into?
I added the tap (the inside one which has a hose attached that goes out through the wall and to the bib tap) on the pipe that goes to the washing machine.
Well, it worked but when I fill the watering can outside, half the water bypasses the inside self-cutting tap and fills the washing machine!
Unfortunately, I cant just turn off the washing machine valve because I would have to pull the machine out each time! So, before I have to rethink the whole thing, is there a washing machine valve that is pressure sensitive? Or rather, is there something I can fit to stop water going into the washing machine whilst I use the garden tap?
Yours hopefully,
Mike the newbie
Yours hopefully,
Mike the newbie
