That's a load of old coblers; I'd never have plastic in my house & I won't use it in bath/shower room renovations I do; he''s probably made a tidy wedge out of the scrap as well.
Nothing wrong with plastic used correctly, move with the times ffs
That's a load of old coblers; I'd never have plastic in my house & I won't use it in bath/shower room renovations I do.
Thanks for your comments. The heating engineer says that the old copper tubes would not work with the new boiler so he had to replace them with plastic. However, that replacement was optional and we decided to go for it to make sure that everything would work perfectly. Is it true that the new boiler requires new plastic tubes?
Yes, soft copper. In the case of u/floor heating (although I really don't know how we got here) the whole point is to transfer the heat in the water in the pipes into the floor, isn't it? The thermal conductivity of copper is far higher than plastic!If someone asked you to install underfloor heating , what would you use?
Copper?![]()
Yes, soft copper
Plastic wouldn't look half as bad if the fittings were not the same size as your average tin of coke.
