All,
I am a bit lost as to the best way forward. Have a 3 bedroom house with 2 showers and a bath.Initially advised by 2 plumbers that the best system to replace my old boiler is a combi. Now another plumber has advised that due to the size of the property best to go for a mega flow system. Has given the following quotation cost of £3950.00. Just wanted to doublecheck whether the cost is ok and most important if there are any hidden issues that should be raised.
Remove existing boiler, cylinder, tank and redundant pipe work
Supply and install Vaillant 630 System boiler and flue
Supply and install 250 Gledhill sealed cylinder
Supply and install new RF1 roomstat
Supply and install new programmer
Supply and install new cylinder stat
Supply and install 2 x two port motorised valves
Supply and install Magnaclean
Supply and install limefighter
Supply and install Sentinel x 100 and x 300 inhibitor
Supply and install all copper tube and fittings
Run condense back to kitchen sink
Run new 22m water mains subject to where the builder leaves it to sink in kitchen and bathroom
Run gas back to the meter
Carry out full powerflush using chemical cleansing agents
Supply electrician to electrically wire boiler components
Commission gas boiler, test and balance system and supply CP12 Gas Certificate
Total cost
£3950.00 for the installation and an additional £600 for running a 22m pipe from the mains to the property.
Total cost
